Message 1 of 4
Contacting a moderator
Good morning,
I have read previous posts which instruct you to review a moderator’s profile and then click contact a moderator.  I have reviewed a moderator’s profile but am unable to see the link.  Apologies if I’m being daft here.  Grateful for some help please.
Thanks in advance
3 REPLIES 3
Message 2 of 4
Re: Contacting a moderator
@nogolftoplay
You cannot contact a moderator, its by invitation only.
What is your issue?
Message 3 of 4
Apologies, on reading previous threads it was suggested that you could so.  No problem, I’ll skin it another way.
Message 4 of 4
Its better to post your issue on this forum, and if it cannot be solved here, and its an urgent issue, then a moderator can be asked to help.
