Message 1 of 2
Currently on 70Mbit, upgrading to 900Mbit, does it stay 70, till engineer?
Good Evening,
I just upgraded my internet and will get the new hub in a few days, however, my engineer visit isn't until the end of April.
I assume I keep my existing speed until after the visit? I wonder because as it stands I believe I'm still copper to the property until the visit.
Does anyone happen to know?
Thank you for your time.
1 REPLY 1
Message 2 of 2
Re: Currently on 70Mbit, upgrading to 900Mbit, does it stay 70, till engineer?
Your assumption is correct. Your current broadband speed is the physical limit that your copper line can run at. The upgrade involves running a new fibre all the way into the house, which is why you'll need at least 1 engineer visit.
