Message 11 of 14
Re: DLM reset with a TP Link router.
Yes, it looks like DLM has got one more step to 3dB margin, you are currently at the 4dB step.
Message 12 of 14
That’s interesting. I had no idea there were steps. I assumed it was a simple on or off situation.
Good to know and something to look forward to. Thank you.
Message 13 of 14
Another 2 days of uptime and another resync, this time with a margin of 3.1db, a sync rate of 75mbps and a max attainable close to 79mbps.
It’s taken 4 days since reconnecting the HH5 for things to improve dramatically. It’s 8mbps higher than it was this time last week.
I’m suspicious now that my TPLink router, a VR600 V1, was holding it back. It’s one hell of a coincidence.
Either way, this one is definitely solved now. Thanks for the help everyone.
Message 14 of 14
I had a VR600 V2 when I was on FTTC and after a few days I had to get rid of it... It was overheating and constantly dropping the 5gHz connection. That hardware is a piece of nothing... Avoid it! 🙂
