Message 1 of 2
DLS uptime & Network uptime
Recently went from fibre 1 to Fibre 2 but after having issues with my line I always check the BT smart hub manager, on status the network uptime is 42 minutes but on technical log it says over 1 hour.
There is a 20/30 minute time difference, before the switchover everything in smart hub was perfectly in sync. Do I need to reset my router?
1 REPLY 1
Message 2 of 2
Re: DLS uptime & Network uptime
if your internet is working ok then why bother causing a reset to the hub
I would normally expect my system uptime to be slightly longer than my dsl connection time after system/factory reset
