Message 1 of 14
DNS Issue Xbox and Facebook not available.
Hi,
I cannot access xbox.com or facebook.com. NSlookup shows the same IP address for both domains ie. 81.130.111.239 which is incorrect.
If a do an nslookup using google dns it works and I get correct responses.
This means xbox gold is not working via BT smarthub.
I cannot change the servers they are hardcoded.
BT say its the hub and a need a new one. I doubt this very much.
Any ideas or has anyone else had the same.
13 REPLIES 13
Anonymous
Not applicable
Message 2 of 14
Re: DNS Issue Xbox and Facebook not available.
Try a factory reset of the hub
Message 3 of 14
Already tried that.....as suggested by BT.
Message 4 of 14
FYI.
If i run a VPN, it works....no surprise as it is using different dns servers. Unfortunately you cannot use VPN's on an xbox one.
Anonymous
Not applicable
Message 5 of 14
Try running the VPN on the laptop and set it up as a Wi-Fi hotspot then connect your xbox to that
Message 6 of 14
That's an idea. Can you suggest a hotspot software to use.
Also this has to be a bit issue with their DNS.......
Anonymous
Not applicable
Message 7 of 14
Windows 10 has a built in hotspot capability, just go to settings and search hotspot
Message 8 of 14
Xbox One:
  1. From the Xbox One home screen, go to Settings > Network > Advanced settings > DNS settings > Manual. (If Settings doesn't appear on the home screen, select My Games & Apps, then Settings.)
  2. From there, enter the Primary DNS as "208.67.222.222" and the Secondary DNS as "208.67.220.220"
Message 9 of 14
Cheers for all the help. Will have a play this morning
Message 10 of 14
The DNS settings workaround did not work. Not sure why
