Message 1 of 13
DSLChecker G.fast miss match
Hi all.
Just wondering, (ill post images) when I run the DSLchecker for my number it states I should be getting 330mb solid as im  10m from the cabinet.
 my maximum data rate used to be 400+ that has dropped 50% thus lowering my sync speeds, being my proximity to the cabinet and on brand new copper (12 months old) do I have cause to ask this be investigated?
 so from 400+ to 191.8 is more than 50% reduction. I know my line should be getting a much better speed than it is.
Thanks.
12 REPLIES 12
Message 2 of 13
Re: DSLChecker G.fast miss match
Do you have a dila tone on your landline?  If so dial 17070  option 2 should be silent and best with  order phone  any noise is problem
Message 3 of 13
Only have a cordless, but it seems fine doing the quiet line test.
Message 4 of 13
I'd report it as the noise magin appears to show an issue with the line.
Message 5 of 13
I've been on the phone to BT just fobbed me off as im achiving the 150mb guarantee I'll try again.
Message 6 of 13
So apparently there are no faults showing.
Noise margin as of now is 16/27
I'm guessing the DLM has set it to that for some reason. Im not to impressed that upgrading from fibre 100 to fibre 250 has given a 7mb increase.
When the engineer installed my new copper last year said this line can handle g.fast to it maximum capacity, and now its struggling to hit 200mb
Found an image from my stats 2019 max data rate is 401 and a pinned sync speed nothing has changed either.
Message 7 of 13
Now that noise margin is understandable due to the max available being so high.
Message 8 of 13
So saying that the is definitely somthing amiss here, dont you think??
Message 9 of 13
I think you need openreach engineer visit as speed should be better just looking at dslchecker results  the odd thing is the attainable significant reduction so not just provisioned  wrong as that would just affect the connection speed
Message 10 of 13
On the phone to CS, they said they can't send an engineer out as there is no faults showing on the line.
Can the mods here provision an engineer visit?
Feel like I'm being fobbed off by the telephone people, halo 3 states a 250mb speed guarantee, yet on my account says 150?
If they can't up the speed might aswell go back on fibre 100.
