Message 1 of 4
Digital Voice Equipment
Apparently my phone line is changing to digital voice tomorrow. I’ve been trying to order an adapter using the link in the email but just keep getting this error messawhen I enter my phone number:
The number entered is not eligible for this offer. Please check you have entered your number correctly.
3 REPLIES 3
Message 2 of 4
Re: Digital Voice Equipment
numerous posts like yours  try phoning CS 150 or 0800800150 from mobile and order
Message 3 of 4
Thanks.
If there are numerous posts then it's frankly about time BT sorted it out ....
Message 4 of 4
As long as you are using SH2 you can connect existing phone to socket on back of hub - you may have to remove sticker first
