Message 1 of 8
Digital Voice Extenders
I'm absolutely astonished at the poor implementation of digital voice thus far.  It's made worse by the total lack of knowledge at the BT call centre.  Nobody yet can answer basic technical questions.
So, my question to this generous community is as thus:
We now have digital voice and two new digital voice phones.  I need to distribute the phones throughout our labyrinth of a property and despite the protocol being DECT, it just doesn't penetrate 18th century walls everywhere.
BT have offered the Digital Voice Adapter but unable to confirm (seeing as it appears to enable older handsets to connect to the SMART hub) whether a newer digital voice handset will/can connect.
In other words, if I distribute voice adapters around the property and connect them to the SMART hub, does this enable the new digital voice handsets to connect (and thus creating a form a DECT mesh or extension)?
Many thanks.
Adrian
7 REPLIES 7
Message 2 of 8
Re: Digital Voice Extenders
the adapters are just for connecting old style phones not to extend DECT coverage
this thread may help with alternative
https://community.bt.com/t5/Home-phone-including-Digital/Correct-way-to-enable-all-BT-sockets-after-...
Message 3 of 8
Thank you.
Sadly, we only have one socket in the property and that's where the SM2 is positioned.
If the adapters are not extending the SM2 DECT, then what are they doing?
Ironically, one way of extending the digital voice reach is to implement these but with old phones hanging off them?
Adrian
Message 4 of 8
Thy are effectively extending the analogue phone socket on the SH2 via DECT.  Why they aren't also a DECT extender I have no idea!
Message 5 of 8
OK - that's madness.
So, they extend using DECT but only permit a direct wired connection to a handset...
Message 6 of 8
As far as I'm aware, yes!!
Message 7 of 8
They are are DECT receivers, just like a normal DECT handset. They just present an analogue interface so people do not have to make a physical connection to the home hub, which may not be in a convenient location.
DECT repeaters are far more complex, and very expensive.
Message 8 of 8
I asked the same question and it went to BT support.
That was nearly 2 months ago.
No answer yet so you have to put with the poor signal.
You cannot use an extender as it looks like the desingers forgot to implement this in the Hub 2.
Obviusly this was well field trialled and the support goup are on top of it  - NOT!
