Message 11 of 12
Re: Digital Voice problems in big old house
Yeah, as long as you have spare wires in the cable you can do all sorts of things.  Basically you just need 2 wires for the hub broadband and 2 other wires to distribute the telephony. Just keep broadband and telephony separate. If the master has a filtered faceplate, just connect the pair going to the hub to the data extension terminals and the pair going to the new phone-only socket to pins 2&5
Message 12 of 12
Yes! That's a great idea; this never occurred to me. I'll give it a try if the adapters don't work out. Cheers!
