Message 321 of 411
Re: Digital Voice with different Router
I tried the route of bypassing BT router by turning everything in that router off and using it as a wan port to my TP-link router so only link is lan to wan connection and wan out to internet. You can't turn off the Smart setup of smart hub because all it does it reboot router
wifi from tp-link using port forwarding works great and internet stays on, but that smart setup must be the random rebooting causing issue with skyQ
Message 322 of 411
Smart setup no longer exists on the Smart Hub. It was permanently disabled by the last firmware update.
Message 323 of 411
It does show up as smart setup but then changes to reboot
Message 324 of 411
There is no smart setup. Can you post a screenshot
Message 325 of 411
Do you mean Smart Wireless? If so, you can select channels manually but you need to save the changes.
Message 326 of 411
Sorry if I sound like a tech but I have spent years setting up routers and internet and electrics as i am an electrician engineer 30+ years and was doing it before you even had a pc
Message 327 of 411
I very much doubt that, but hey ho.
Message 328 of 411
@licquoriceI believe you can still turn off smart this way.
If you log on as admin enter the password then open another browser tag and use this link http://192.168.1.254/smart_setup.htm
You can turn it on/off there
Message 329 of 411
Yes, but it is off by default and not visible under normal access.
I suspect that @Mrlewisuk is referring to Smart Wireless rather than Smart Setup but doesn't like to admit it.
Message 330 of 411
If I had the info I would build a modem but but would need the coding from openreach to connect with BT. I can build a pc no problem,
most don't change the security login on routers
