Message 1 of 3
Digital Voice
Hi
We recently moved onto Digital voice. Our SH2 is at the extreme end of the house so we have 3 mini discs extending the wifi - all works well. Plugging the existing dect base station into the back of the SH2  means only the phone near the SH2 and one other can get a decent connection. How can I extend the range of the dect phones to other parts of the house?
2 REPLIES 2
Message 2 of 3
Re: Digital Voice
@GTC1948
You could plug the base unit into the BT Digital Voice Adapter. BT will supply it free.
https://www.bt.com/help/user-guides/phones/digital-voice/digital-voice-adapter
You could then locate the DECT base unit at its original position in the house, where I assume you used to get good coverage.
Message 3 of 3
Re: Digital Voice
Great - thanks for the help
