Message 1 of 2
Do the BT Broadband Parental Control Settings Carry Over to the BT Hot-Spots?
Do the BT Broadband Parental Control Settings Carry Over to the BT Hot-Spots? If not, can Parental Settings or Controls be applied to BT Hot-Spots?
1 REPLY 1
Message 2 of 2
Re: Do the BT Broadband Parental Control Settings Carry Over to the BT Hot-Spots?
If you mean BT WiFi hotspots as opposed to powerline hotspots within your house, then the answer is no to both questions. However, access to BT WiFi hotspots requires your password to log in.
