Message 1 of 5
Does BT Infinity throttle Instagram?
I'm a BT infinity customer utilising 70mb line. Generally I'm very happy with the service, but Instagram is a pain in the neck. I use this service a lot, but it appears my connection to this service on my phone over wifi appears throttled?
I know this probably isn't the case as if I connect via ethernet, the site loads up just fine.
What would cause a problem over wifi? Every other site works perfectly fine, it is literally just Instagram over wifi??
4 REPLIES 4
Message 2 of 5
Re: Does BT Infinity throttle Instagram?
BT don't throttle it probably just a problem with your wifi
Message 3 of 5
Thanks for quick response. I mean, yes, it's obviously something with wifi - any ideas what it could be?
Message 4 of 5
They should throttle the Rich Kids of Instagram. They’d certainly be doing the entire World a massive favour.
Message 5 of 5
I realise this is an old post but wondered if there was any way one could 'fix' or 'adjust' the wifi so it wasn't throttling Instagram. It's the only app I use that I need to come off of wifi in order to use it.
Any suggestions on what can be done?
