Message 1 of 4
Does the Halo 3 hub have ethernet connections?
I have the previous hub (fibre2?)which I seem to think has at least 4 ethernet connections.
I am looking/considering the full fibre but I really need/prefer CAT5 connections as 2 of my machines (home and work) are sat next to the hub so cabling is not an issue
3 REPLIES 3
Message 2 of 4
Re: Does the Halo 3 hub have ethernet connections?
Halo is a package add-on not a hub. The smart hub2 has 4 Ethernet ports which can be  used **bleep** 4xLAN if you have FTTC or 3xLAN and 1xWAN if you have full fibre FTTP.
Message 3 of 4
Cheers, yes meant the hub not the package. assuming I get the new hub2 if I upgrade my package
Message 4 of 4
Hi @paulmoxon   You do not get a new Smart Hub 2 with Halo 3 for FTTC. To upgrade your Router you need Complete WiFi or Halo 3+.
