Message 1 of 2
Smart Hub 2 firmware upgrade
Hi,
Just wondering if anyone knows if there is a firmware upgrade on the horizon for Smart Hub 2?  I have been waiting several months for this, in the hope it will allow me to split 2.4 & 5GHz wifi.  I had problems with 2.4GHz wifi periodically ceasing transmission.  BT told me that it prioritizes the 5GHz output, so I have rolled back to using HH6, which has been great except that wifi is weak at the back of the house and my wifi extender has just died!
Thanks.
1 REPLY 1
Message 2 of 2
Re: Smart Hub 2 firmware upgrade
I very much doubt there will be a firmware upgrade to allow this as it is deliberate not a bug.
@bigdave17 wrote:
Hi,
 BT told me that it prioritizes the 5GHz output!
No idea what they meant by that, nor do they I suspect.
