Message 11 of 13
Re: Downstream and upstream are much slower than what I should be getting
I've rebooted a couple times but I stopped doing that because nothing changed
Message 12 of 13
A couple of time could be any number. The fact is that is the worst thing you can do with a VDSL connection as DLM would see it as a fault. That said your noise margin is excessively high which would support too many reboots or as @Keith_Beddoe  says a problem with your line. As you report the QLT as being silent you are going to have to bite the bullet and call it in.
Message 13 of 13
I agree with @pippincp .  Your max data rate is fine, but DLM has detected an issue, and reduced your connection speed. Multiple restarts will also cause that.
