Message 1 of 2
Downstream line rate falls from 75Mbps to 2Mbps
Hi,
I'm just back from a couple of weeks holiday to find my fibre broadband has a downstream line rate of only 2Mbps to the router (it's usually ~75Mpbs). I've tried rebooting, using a different router, leaving off for an hour etc but nothing changes the speed. Any ideas?
Thank you,
Steve.
1 REPLY 1
Message 2 of 2
Re: Downstream line rate falls from 75Mbps to 2Mbps
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
