Message 1 of 5
Drop users connected to HomeHub 4
Hello, I have a Homehub 4. I am working from home and live in a remote area so the bandwidth can be pretty poor. Sometimes I lose connectivity on web based conference calls usually when the rest of my household are connected to the internet and streaming etc. Is there a way on the console that I can kick them off the network and dont let them join back until I say so without having to leave the room and shout at everyone to stop using the internet lol
Many thanks.
4 REPLIES 4
Message 2 of 5
Re: Drop users connected to HomeHub 4
if you are using an ethernet connection and rest using wireless then you could just turn of the wifi from the hub
you need a 3rd party modem router which would allow you to prioritise your connection over others
Message 3 of 5
Thanks for the reply @imjolly so it looks like the hub is limited in capability.
If I purchased a router that allows connection prioritisation do you know if you can weight or throttle connections?
Message 4 of 5
Yes many routers allow that facility.  Popular is tplink and more facilities the more expensive.  You can check the forum posts for suggestions
Message 5 of 5
Yes, you can adjust priority.
I assume you are using a HH4 on an ADSL connection?
Then this router will allow you to control priority and bandwidth to each user.
https://www.tp-link.com/uk/home-networking/dsl-modem-router/td-w9970/
Controls are applied per LAN IP address, so have to be reserved first via DHCP address reservation. I use that same router on my ADSL connection.
