Message 11 of 12
Re: Ducting 54mm
Thank you for the reply. We know the ducting to use but can't establish if two properties are 'share' the ducting.
Message 12 of 12
Re: Ducting 54mm
What are you asking exactly?
Are the 2 homes Semi Detached and have a Duct in the middle of the two?
I suppose you could but it might cause a boundary issue later on if one neighbour decides to play the ****hole card.
