Message 1 of 3
Ethernet cabling
I want to get my computer setup with an ethernet cable and I found a socket labelled NTEC5 MK2.
Can I just buy a CAT8 which seems to be a high speed cable directly connected to my computer?
I already have a fibre broadband setup wired from the outside towards another location in the house for the router and TV.
And if I could directly setup from the NTEC5 socket, what do I need to do for multiple setups?
Thanks!
2 REPLIES 2
Message 2 of 3
Re: Ethernet cabling
Not sure what you are trying to achieve here. NTE 5 is a telephone socket, Ethernet is not available until you reach the Smarthub (unless you have full fibre).
Can you provide more detail about what you are trying to achieve?
Message 3 of 3
The computer needs to connect to the home hub (router) not the telephone socket you found.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
