Message 1 of 2
Event log query
Hi all,
Apologies if I've posted this in the wrong section.
The following has appeared on my event log and I've not seen it before and couldn't find any information on it on the internet, I wondered  if it's anything to be concerned about:
16:12:16, 07 May.
Self roaming might be occurring... Deauth original one..."
Many thanks in advance
1 REPLY 1
Message 2 of 2
Re: Event log query
@pg4
You will need to specify which version of the BT Home Hub you are using, and whether you have any of the black complete wifi discs in use. Then you may be able to get some advice from other BT Broadband customers
