Message 1 of 9
Exchange Alarm
I've just been past Exchange WWSPET and there is an alarm sounding.  At the entrance there is a repeating voice saying "Fixture Alarm" or something similar.
Building looks, on the face of it, to be secure but I did not want to start trying handles and doors.
I'm sure this things get reported by the alarm system centrally but for completeness I thought I would throw it on here for a Mod.
M 😉
8 REPLIES 8
Message 2 of 9
Re: Exchange Alarm
It has nothing to do with BT RETAIL. You need to report to openreach
https://www.openreach.co.uk/orpg/home/submitFeedbackLoggedInUser.do
Message 3 of 9
Re: Exchange Alarm
@Slvrbck
It will be "System Alarm" and will be seen by the alarm monitoring people, so nothing to worry about. A moderator could not deal with this.
You may see a number printed on the wall outside of the exchange, if you are concerned, then give them a call.
It may be worth calling through to BT Security on 0800 321 999 to report this.
Message 4 of 9
Re: Exchange Alarm
Nothing to do with Openreach.
Message 5 of 9
Re: Exchange Alarm
Both the chappy at BT and the lady at BT security were aminable.
Message 6 of 9
Re: Exchange Alarm
They should be, as they do rely on public help. Leave it like that and do not place yourself in any danger, as there may be intruders you cannot see, usually after cable.
Message 7 of 9
Re: Exchange Alarm
Bless you 🙂
I'm a sensible, big hairy thing with a big grumpy bull dog and I'm not silly enough to put myself at risk for a bit of BT kit but I appreciate the sentiment. 🙂
If I'm honest I think I heard it last night...
I'm guessing it just needs a reset but it does beg a question about the monitoring...
Message 8 of 9
Re: Exchange Alarm
Its more likely to be a false alarm due to a door not closing properly. The rain and wind tend to do this. I am a BT pensioner, but have worked in the exchanges for nearly 42 years.
Message 9 of 9
Re: Exchange Alarm
I sure you are correct.  It's just the Boy Scout an a healthy bit of technical OCD in me that makes me do something 🙂
I'm closer to pension than school so appreciate the value of experience 🙂
