Message 1 of 7
Extending network to a garden room
Hi all. Currently having a garden room built and will be having an Ethernet cable running from my smart hub 2 out to a data port in the room. What would I need to connect to that data port in order to use the existing BT Wi-fi network (if this is possible!)?  I’ve looked at WAP’s but think this will create a new Wi-fi network and therefore a Sky Q box will not work in the garden room.
Many thanks and apologies for the long post!
6 REPLIES 6
Message 2 of 7
Re: Extending network to a garden room
Just connect a wireless access point (WAP) it will have a different SSID to the hub but will be on the same network. You can change the SSID if you wish to.
Message 3 of 7
are you actually connecting a SKYQ main box or a mini?  if mini remember it has to be able to connect to the main SKYQ box
Message 4 of 7
Thanks for the reply.  It will be a mini so think I’ll test it with one of the other boxes out there before ordering one. I thought it had to be in  the same network!
Message 5 of 7
Thanks for the reply. If I changed it to the same SSID as the BT hub, would that work or cause me issues?
Message 6 of 7
@Cookie3004
Surely the Sky Q mini can connect over ethernet , my son has them & I'm sure his are ethernet connected.
Message 7 of 7
@TimCurtis
you can run cables all over to connect the main SKY Q box to the minis but they are now all wifi and the main SKY Q box sets up a mesh system to connect to the minis
