Message 1 of 2
Smart Hub 2 Wi Fi problems
Hi,
Since a couple of weeks all my WiFi connected devices are suffering intermittent Internet loss, regardless of their location relative to the Smart Hub 2.
The main PC, which is connected to the Smart Hub 2 through an Ethernet connection, is fine. Broadband speed test on the main PC shows excellent speeds even during these WiFi outages. So it seems the WiFi signal produced by the Smart Hub 2 is unstable (flaky).
Has anyone else experienced this issue and if so, is there is a fix? Rebooting the Smart Hub 2 had no effect.
1 REPLY 1
Message 2 of 2
Re: Smart Hub 2 Wi Fi problems
Have you trie a factory reset by holding button on back for 20/30secs until lights flash
when reboots remember turn of smart setup
