Message 1 of 3
Extending power cable for BT Mini Disc, 2.5 or 2.1mm?
I have my router on top of a cabinet and the cable length for the BT Mini Wifi Disc isn't long enough, so i wish to extend this.
Can anyone tell me if the plug size is 2.1mm or 2.5mm please?
I can't see it mentioned anywhere and don't have the instrument to measure such a small amount.
I'm thinking of using a 5.5 x 2.5mm (or 2.1mm) DC Power Plug to Socket Extension Lead Cable 1.5m
Thank you for any help.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Extending power cable for BT Mini Disc, 2.5 or 2.1mm?
The wholehome discs are 2.5mm, I assume the Premium WHW and the black discs are as well.
Message 3 of 3
To confirm for any future reference the sizing for the BT Wifi Mini Disc is 5.5 x 2.1mm.
