Message 1 of 2
External router
Hi all
Can you use a third party router like asus with the bt home hub 6 or do i need to get another modem ?
 Cheers
1 REPLY 1
Message 2 of 2
Re: External router
the home hub does not have a modem only mode.  if you want to use 3rd party router better with a modem router unless you specifically want separate modem and router
