Message 1 of 3
F900 issues
https://www.ispreview.co.uk/index.php/2020/07/isp-bt-working-to-fix-slow-fttp-broadband-speed-profil...
Is any one else experiencing issues? my speed is around 500mbps / 100 mbps
2 REPLIES 2
Message 2 of 3
Re: F900 issues
If you use the search function you'll find plenty.
Message 3 of 3
Re: F900 issues
Probably not what you want to hear but if you purchase a "quality" router that can handle the 910 / 110 package you won't have anymore problems.
It seems the supplied HH2 is not up to the job in most cases.
As quoted plenty to read about if you search the forums.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
