Message 11 of 30
Re: FAULTY BROADBAND SERVICES, NOT MEETING MINIMAL OBLIGATIONS AND DELAYING EXITING
@ashoktp wrote:
6
I checked the hub and phone or connected as in the picture
Is the hub plugged directly into the top socket? You must not use any microfilters.
If it is, then its possible the master socket is faulty, and you need to check at the test socket. I assume you are getting dial tone on your phone?
Message 12 of 30
Yes. The hub is directly connected to the top socket.
Have  called BT and  hoping something will be done soon. I am just getting 1-2 MBps at the moment.
Message 13 of 30
The test socket is shown by black arrow after removing the middle section shown by yellow arrow
Message 14 of 30
The phone line is ok and getting dial tone
Message 15 of 30
Please can you post the results of this test.
https://speedtest.btwholesale.com/
Message 16 of 30
Will check. Do i need to connect phone line to check socket and check the status ?
Message 17 of 30
Are you able to post stats from your hub or router as that would help
Message 18 of 30
Just run the speed test, as I notice you said 1-2MBs, which would normally mean MegaBytes/s which is not the same as Megabits.
The speed test will return the correct speed results.
Message 19 of 30
PING
32
ms
DOWNLOAD
1.86
MBps
UPLOAD
0.73
MBps
Message 20 of 30
Broadband Speed Test
Executed Successfully
PING
32
ms
DOWNLOAD
1.86
Mbps
UPLOAD
0.73
Mbps
