Message 1 of 10
Looking for a router that is BT compatible
Hello,
We're looking for a high end router that is BT compatible, we've noticed that some are not and tbh no idea which are and which aren't
Can anyone recommend a good one?  Looking at TP-Link or Netgear or any other reputable brand.
Thank you
9 REPLIES 9
Message 2 of 10
Re: Looking for a router that is BT compatible
@JaywR10
What type of connection do you have?  It's its regular Fibre to the Cabinet (FTTC) you need to look for a VDSL compatible modem/router.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 3 of 10
I have a Netgear X6 R8000 Nighthawk connected directly to the Openreach ONT. Works well!
Message 4 of 10
Hi
Its as you say, its connected up to a FTTC via a PSTN line.
Any recommended routers for this type of connection
Thank you
Message 5 of 10
Hi
Will this work with my setup as mentioned above?
Thank you
Message 6 of 10
TP-Link, whichever model suits your needs.
Message 7 of 10
@JaywR10
Depends on your budget,
here are DSL Modems & Routers | TP-Link United Kingdom (tp-link.com) and Gateways | Telco | Service Providers | NETGEAR
Personally I use a Fritz!Box 7530.  Had no issues so far.
Kind Regards
CJT80
Message 8 of 10
@JaywR10 wrote:
Hi
Thank you
This one is very popular, and works with all BT services including BT TV.
https://www.tp-link.com/uk/home-networking/dsl-modem-router/archer-vr400/v2/
If you only want 2.4GHz then there is a cheaper option.
https://www.tp-link.com/uk/home-networking/dsl-modem-router/td-w9970/
Message 9 of 10
I've been using the VR400 above for quite a few years now with no problems at all. (FTTC)
Message 10 of 10
I personally used a Draytek Vigor 130 VDSL modem (which is guaranteed by Draytek to work with the BT connection) and a separate Nighthawk R7800 Router, connecting them together via the routers WAN port.
It has been more stable than the BT home hub (that one kept rebooting and finally started crashing when the sun came out).
However, I have also just switched to BT mini disks rather than use the routers Wifi because a mesh wifi system is so much more convenient and the BT mini disks are really good value. If I had gone this way initially, I would probably have chosen the Vigour modem with a Ubiquiti Edgerouter X with the Mini discs
