Message 1 of 4
FTTP 3rd Party Router Setting Please - for Asus DSL-N66U or similar
Good news - I finally have my 300Mb FTTP and so far it seems to be worth the wait.  Bad news - I can't make my ASUS router work with it.
I've been through every related thread here that I could find and used any settings mentioned by others, but every time I fail to get a connection.
The ONT sees the router (or at least, the correct light comes on).  But no matter what selection of settings I choose the router can't see the ONT as a device with an IP and I'm stuck with the yellow warning symbol for no internet connection. I've generally used the default settings unless I've found an alternative recommendation.  It's connected via the WAN port and I have the settings (and options) in the list below.
Can anyone tell me where I'm going wrong please?
Thanks  🤞
p.s.  apologies that this has opened as a new thread, I was trying to post in my original from a couple of weeks ago!
WAN/Internet Connection
WAN Transfer Mode – ADSL LAN(ATM) / VDSL LAN (PTN)/ Ethernet WAN   -   VDSL (also tried Ethernet WAN)
Service Unit – Internet  (other options are Bridge 1 to 6)
Enable – Yes
Basic Config  IP Version – IPv4
Connection Type – PPPoE
Enable uPNP – Yes
802.1Q  -  Enable – Yes  (also tried No)
VLAN ID  -  101  (1-4094)
IP Universal Settings  -  Default Route  -  Yes
MTU   -  1492 bytes  (default)
IPv4 Setting   -  Get WAN ID Automatically – Yes
Connect to DNS Server Automatically  -  Yes
Enable NAT  - Yes  (tried No also)
PPP Setting  -  Username  -  [email protected]        Password  -  bt
PPP Authorisation   - CHAP   (also tried PAP and AUTO)
TCP MSS Setting  0 bytes  (default)
NAT Passthrough Settings – all set to defaults
PPTP Passthrough  -  Enable
L2TP Passthrough  -  Enable
IPSec Passthrough  -  Enable
RTSP Passthrough  -  Enable
H.323 Passthough  -  Enable
SIP Passthrough  -  Enable
Enable PPPoE Relay  -  Disable
3 REPLIES 3
Message 2 of 4
Re: FTTP 3rd Party Router Setting Please - for Asus DSL-N66U or similar
Message 3 of 4
No, sorry, my senior moment typo when coplying the ID. I have the correct one ..... @btbroadband.com . It doesn't work, something else is the issue.
I've just spent another jolly hour playing with every combination of settngs I can come up with - no joy. I'd be grateful for any other thoughts or ideas.
Message 4 of 4
@ChunkyTheCurmudgeon
Have a look at this thread.
