Message 1 of 6
FTTP Ethernet Speed Slow
We have recently moved into a house that has FTTP internet which has ethernet ports wired throughout the house.
We have a smart hub 2 and when we plug the ethernet into the correct port, our internet speed sky rockets but it doesn't maintain that speed.  It'll stay around 600MB for a minute then go back down to under 100.
Does anyone know why this is?
Thanks for your help!
5 REPLIES 5
Message 2 of 6
Re: FTTP Ethernet Speed Slow
Have you tried connecting directly to the hub to rule out problems with your internal wiring?
Have you tried a direct PPPoE connection from a PC/Laptop to the ONT to rule out problems with the Hub?
Message 3 of 6
I connected to the hub and the same thing happened, do you think the issue is internal wiring then?
Message 4 of 6
Not if you get the same problem when connected directly to the hub, you have eliminated your internal wiring.
Try a direct connection to the ONT, have a look here if you are unsure how to do that. Username is [email protected] and password BT.
Message 5 of 6
Thanks, tried that and it failed with error 651.  Does that mean it is the hub?
Message 6 of 6
If you follow @licquorice 's instructions you do not connect to the hub, you connect the PC directly to the Openreach ONT (box on wall).
