Message 11 of 31
Re: FTTP Install underground v overhead
Here's the overhead line. Could overhead fibre lines be run under these power lines?
Message 12 of 31
That is high voltage, I suspect @Starwire  will be along at some point to confirm if it is possible, but I suspect not.
Message 13 of 31
Yeah, that’s HV. It will either be 11k or 33k
11k you can put drop wires under them but with a minimum clearance of 1.8m. Bear in mind the drop wire needs to be at least 5.9m above the road.
If it’s 33k then you can’t put drop wires under it all.
Given your end of the road has the phone lines UG I’d hazard a guess it is 33k anyway.
Message 14 of 31
ok thanks Starwire. Sounds to me like it's going to have to go underground then?
If you were the engineer who rocked up at the end of the month, what is the most likely option if it's high voltage? Would a new fibre cable have to be run underground and then my driveway dug up – which would take months?
There are about 20 houses not served by cables at the end of the street if that makes any difference.
Message 15 of 31
If you have a phone line to your house today then I assume it goes underground in a duct.
Surely they'll just push the fibre through that, same as they do for any property that doesn't have telegraph poles?
Message 16 of 31
Depends when it was built and by who. A lot of cabling was buried Direct in Ground during the 60’s/70’s to reduce costs.
Even Ducting being place doesn’t necessarily mean it’ll be a easy as pushing it in, which they don’t do anyway, it’s Rod, Roped and pulled through. The Duct could be congested, blocked or if there’s Swept T’s involved you have to pray the put them on the right way round when it was built.
Message 17 of 31
Ah, see what you mean.
Message 18 of 31
My neighbour three doors up is showing as Single Dwelling Unit Residential UG Duct rodded and roped, presumably this is a database error for my house.
I can't see how fibre could be brought to replace below wiring without digging. Are there some special tools to replace the copper with fibre?
Message 19 of 31
The maximum dropwire length is still 68 metres. The new 75 metre and 85 metre rules apply to spans between poles. If the measured distance is greater than 68 then they will have to look at a UG solution for your feed or possibly drop a carrier pole somewhere. The equipment used to connect to your house is called a CBT and is mounted at the top of a wooden pole or inside a hollow pole utilising a CBT specifically for hollow poles called a "squid".
Tags (1)
Message 20 of 31
@AnMadraRua68 mtr dropwire refers to copper connections. This thread refers to FTTP.
