Message 1 of 5
FTTP Modem - spare Ethernet port
I wish to use Ethernet to connect to my home office. Can I simply plug into a spare Ethernet port on the modem or must I connect to the Hub?
Kind Regards
Hugh
4 REPLIES 4
Message 2 of 5
Re: FTTP Modem - spare Ethernet port
connect to hub
Message 3 of 5
There is only 1 active ethernet port on the ONT. The others are disabled. The newer ONT's only come with 1 ethernet port.
Message 4 of 5
Got it! Many thanks
Message 5 of 5
