Message 1 of 7
Clean Lines and Impacted Lines
I have G.fast. When I look at the Broadband checker, it says that available speeds are between 149Mbps and 123Mbps for a clean line and between 117Mbps and 75Mbps for an impacted line.
When first installed by the Openreach engineer about 12 months ago I was generally connecting at about 134Mbps, so clearly a clean line. Now the Smarthub is reporting that it is connected at 105 Mbps with a maximm possible speed of 108Mbps so clearly impacted.
As nothing has changed at my end either in terms of wiring or devices connected, what causes a clean line to become impacted and can anything be done about it?
6 REPLIES 6
Message 2 of 7
Re: Clean Lines and Impacted Lines
Hi @northshields there are so many variables it would be difficult to say why exactly your speed has dropped.
Can you please post stats from the hub and we'll take a look? If you have a Home Hub 5 then go to http://192.168.1.254 then go to troubleshooting, helpdesk. If you have a Smart Hub its advanced settings then technical log information enter your phone number and post results.
Also is there any line noise on the line?  You can check that by calling 17070 from your landline and choosing option 2 the call should be silent and its best tried with a corded phone if possible.
Message 3 of 7
Product code:Smart Hub 2
Serial number:+091299+1939010222
Firmware version:v0.21.03.07094-BT
Firmware updated:Wed Oct 14 23:27:17 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:1 days,22 Hours36 Mins38 Secs
Data rate:10.849 Mbps / 94.004 Mbps
Maximum data rate:10.781 Mbps / 109.199 Mbps
Noise margin:3.4 / 2.9
Line attenuation:0.0 / 44.1
Signal attenuation:0.0 / 44.1
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:891.0 MB Uploaded  / 9.4 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-PQA3NM
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:BT-PQA3NM
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:F0:86:20:83:BF:3D
Software variant:-
NeilO,
Thank you for replying. The quiet line test is fine and the Technical Log is set out above. As you will see, since my original post, the speed has fallen even further, so that it is now below my guaranteed speed of 100Mbps, so I will probably have to raise this more formally if it doesn't improve soon. If you are able to throw any light on the matter I would be very grateful.
Message 4 of 7
NeilO,
Just for the sake of comparison, and in case it helps, here is an extract from the BT Broadband Checker showing the speeds which should be achievable.
Message 5 of 7
Hi @northdhields Many thanks for doing those checks, I'm sorry about the delay getting back to you. I can't see anything obvious from the router stats that indicates a line fault, I was expecting the noise margin to be higher which can slow the speed down but that looks ok so I'd recommend giving faults a call on 0800 800 150 and they'll be able to carry out further in-depth checks on the line and connection. Post back and let me know how you get on?
Message 6 of 7
NeilO
By way of an update, I ran the online fault checker which duly recognised that the speed I was getting was less than it should be and a fault has now been opened and can be tracked. However, the tracking information does seem to be a bit contradictory. On the one hand it says
"Fault in progress
We are still working on the fault and will update you as soon as we know more."
but on the other hand, it also says
"Right to exit removed
We’ve had to remove your right to exit your contract without penalty, as we’ve not been able to monitor your speed or get any required information from you."
Clearly the speed has been tested and I have not been asked for any information which has not been supplied. Do you happen to know what that final sentence really means?
Message 7 of 7
This is now getting ridiculous. On the one hand, the fault I raised is marked as fixed. On the other hand, running the BT Broadband speed tester produces a result that says that the IP profile of the line is 90.88Mbps, which is less than my guaranteed speed. Indeed, the guaranteed speed could never be achieved on that basis.
When BT say that a fault has been fixed what do they mean because it certainly does not seem to be the case. The full test report is as follows.
Performance Test Results Report
Basic Performance Test -
Time Stamp
Thursday 31 December 2020 | 15:53:6
Latency
10 Ms
Download
64.94 Mbps
Upload
10.99 Mbps
Advanced Performance Test -
Download Test
Download speed achieved during the test was 64.94 Mbps
For your connection, the acceptable range of speeds is 63.62-90.88 Mbps
Your DSL Connection Rate: 0 Mbps(DOWN-STREAM),0 Mbps(UP-STREAM)
For your connection, the maximum achievable download speed is 90.88 Mbps
IP Profile for your line is 90.88 Mbps
Upload Test
Upload speed achieved during the test was 10.99 Mbps
For your connection, the maximum achievable upload speed is 30 Mbps
IP Profile for your line is 30 Mbps
Summary Advanced Performance Test -
Result Message
We were unable to identify any performance problem with your service at this time.It is possible that any
problems you have experienced may have been caused by traffic congestion or by a server responding
slowly. Please visit the Speed Test Guidance if you are unable to understand the test results.
