Message 11 of 21
Re: FTTP to Netgear Nighthawk X6 (R8000)
Yes, all working OK.
Make sure the IP address is set to 192.168.1.1
For some strange reason BT have set their default to 192.168.1.254
Message 12 of 21
@JetLag  What difference does it make what the default IP address of the router is?
@Listo  Make sure IGMP snooping is enabled.
Message 13 of 21
It doesn't, as long as one is aware that it may be different to the default of many other routers!
Message 14 of 21
my netgear router's IP is 192.168.1.1
Do you meant the BT TV box's IP?  if so, not sure how I can change that
Message 15 of 21
There is no need to change any IP addresses. Might be worth resetting the BT TV box though to make sure it picks up the changed gateway address.
Message 16 of 21
all working properly now.
Thanks for all the help.
Message 17 of 21
Just a quick note, under your internet settings you have dial on demand and 5 mins. You need to change that to always or else your connection will drop when there’s no activity on the line.
Message 18 of 21
I did wonder about that. Thanks, all done.
Message 19 of 21
Hi there, just curious what fttp speeds you are getting?  Are you on 900 product? Thanks
Message 20 of 21
No, I'm on Fibre 100. I get around 147mbps. With the SH2, this was considerably less in any room other than where the router was. Now I get a good speed all over the house.
