Message 1 of 21
FTTP to Netgear Nighthawk X6 (R8000)
Have got Smart hub 2 that I cannot put in modem only mode.
Is it possible to hook the Netgear Nighthawk R8000 direct to the FTTP openreach box? or do i need a dedicated modem?
20 REPLIES 20
Message 2 of 21
Re: FTTP to Netgear Nighthawk X6 (R8000)
The FTTP Openreach box (ONT) is the modem, you don't need another one. Just connect the Netgear directly.
Message 3 of 21
Thanks, I did try this but it wouldn't connect. I will try again
Message 4 of 21
I have my Nighthawk X6 connected directly to the ONT. No problems!
Message 5 of 21
@Listo  are you entering the correct PPPoE [email protected] with password BT
Message 6 of 21
I thought I had but maybe it's not in the right place. I'm going to reset the router and try again.
Message 7 of 21
what did you change on the router settings?
Message 8 of 21
This works for me!
Message 9 of 21
Great, all sorted. Thanks a million!
I'm not sure what I had done to make it  not work before but it’s firing on all cylinders now.
thanks for all your help!
Message 10 of 21
one more thing, do you have a BT TV box? because mine isn't working now with the new router.
