Message 1 of 3
FTTP
Openreach completed cabling works in my cul-de-sac of 23 dwellings in January this year but when I check to see if I can get FTTP it doesn't show that it's available.  A couple of dwellings can get it.  I've queried this with BT but can't get an explanation.  According to Openreach I should be able to get it.  Can anyone suggest a reason please?
2 REPLIES 2
Message 2 of 3
Re: FTTP
Enter your number HERE and post a screenshot of the result. Remove number before posting.
Message 3 of 3
Re: FTTP
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean) Woodford_0-1628447945931.gif
55.83811.87.634AvailableAvailable--
54.63511.67.130AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
1000220--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+ADSL MaxWBC Fixed RateFixed Rate
Up to 2.5--1.5 to 3.5Available--Yes
Up to 1.5--1 to 2.5Available----
0.5----Available--Yes
0.5----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
61.02
12.21
2021-07-17
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
28-07-2021
Exchange Product Restrictions StatusFTTP Priority Exchange Woodford_2-1628447945937.gif
N
N
Y
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
FTTP is not available.
