Message 11 of 20
Re: Fault reporting
Been waiting on hold for 2hrs now and the lines close at 20:00 I believe - not acceptable!
Message 12 of 20
Re: Fault reporting
Do you have any powerline adaptors?
Have you tried with just one device connected then introduce your other devices one at a time to see if it is a device that is dragging your speed down?
Message 13 of 20
Re: Fault reporting
No powerline adaptors - got a disc - currently unplugged - only my laptop connected at the moment
Message 14 of 20
Re: Fault reporting
From the stats you have posted you had a 20mb connection on 14/6 and currently 17.7mb which is within your expected  speed range
run btspeedtester and post results. Must be done with Ethernet connection
https://speedtest.btwholesale.com/
Message 15 of 20
Re: Fault reporting
Message 16 of 20
Re: Fault reporting
Message 17 of 20
Re: Fault reporting
This may sound daft but when you changed the Smarthub for the new one did you also replace the power adaptor with the new one?
Message 18 of 20
Re: Fault reporting
Message 19 of 20
Re: Fault reporting
No - didn't occur to me - will try it now.
Message 20 of 20
Re: Fault reporting
No improvement with new power adapter
