Message 11 of 24
Re: Fibre 1 to Fibre 2 Regrade
Message 12 of 24
Your uptime is only 5 hours, you possibly have a line fault and getting dropouts. Is there any noise with a quiet line test on 17070 preferably done with a wired phone.
Message 13 of 24
Just done the quiet line test seems fine no noise that I can clearly hear
Message 14 of 24
Is the test line inside the master socket. D0 I  to remove the front?
Message 15 of 24
Yes, it is behind the removable faceplate.
Message 16 of 24
according to stats you have 51/14mb connection with an attainable of 58mb
yes you need to remove front of master to get to test socket  if front just unclips the test socket is visible but if you need to take out 2 screws then test socket here by black arrow
Message 17 of 24
I am now plugged into the test socket. Internet and phone back on working fine. Still at 45down 11up.
Inside box there are 2 wires doing nothing one black one green. 1 orange wire terminated in B. 1 white wire in A.
Does that sound correct?
Message 18 of 24
yes especially as everything is working
can you post new stats as you had better connection speed previously
bear in mind the speeds quoted by BT are connection speeds not download/throughput speed so no point in continuing to quote the lower download speed as they are not guaranteed
Message 19 of 24
Yes, the black and green wires are a spare pair.
Message 20 of 24
