Message 1 of 3
Fibre 1 vs Fibre 2
Hi
I currently have BT broadband Fibre 1 and on my upgrade page there is the option to upgrade to Fibre 2. I cannot see any speed difference, however came across a post which mentioned using the BT line speed checker: https://www.broadbandchecker.btwholesale.com/#/ADSL
My results are as follows:
Is anyone able to interpret the results to help me decide if Fibre 2 would give me the additional speed?
Many thanks
RB
2 REPLIES 2
Message 2 of 3
Re: Fibre 1 vs Fibre 2
Fibre 2 won't give you a speed increase, your speed is well below the fibre1 threshold.
Message 3 of 3
Thank you for the quick reply. Much appreciated
