Message 1 of 2
Fibre 100, but upload max of 5Mb
When i first got Fibre 100 i had downloads of 147Mb and uploads of 30Mb.
Today im getting the same download but my upload is capped at 5Mb. However if i use the BT test it says im getting 31Mb but no other test agrees and they all say the same 5Mb.
Ive reset the router with no effect.
1 REPLY 1
Message 2 of 2
Re: Fibre 100, but upload max of 5Mb
Hi @robj20,
Welcome to the Community and thanks for taking the time to post.
Sorry to hear that you are having problems with your connection. It would be best to raise a fault to our FTTP team so that they can look into this for you. You can do this by calling 0800 800 151.
Matt
