Message 11 of 17
Re: Fibre 150 no calls
Hi have asked them to do a line check and they text Backford say no landlines registered for my number
Message 12 of 17
Hi logged in tablet and shows phone symbol as not configured
Message 13 of 17
have you checked for service problems in your area?
https://www.bt.com/help/check-service-status
Message 14 of 17
Yep first thing I checked, if I have not been put on dv calls then my phone line should still work as the £39.99 says it includes line rental is that right?
Message 15 of 17
No line rental is included even if you have broadband with no landline service included.
What products does MyBT say for your account? www.bt.com/mybt
Have you recently upgraded and selected to not have a landline service?
Message 16 of 17
All sorted bt had cocked up order and didn't transfer phone over now on dv with a couple of free phones for my trouble should we have kept our existing number?
Message 17 of 17
Hi @Thsjp01,
Thank you for posting back to let us know the issue has been fixed. You should have been able to keep your number when you were switched over to digital voice.
Thanks,
Paddy
