Message 1 of 14
Fibre 2 Upgrade - Slower Speed
Hi all,
I have just upgraded to BT Fibre 2 from an old Fibre subscription which had 6 months left.  For the extra £2 a month and a guaranteed 45mbps I thought why not!  Previously only maxing out at 36mbps (YES less than the 38mbps guarantee).
So on 1st October the activation took place.  Since then my speeds have crashed.  Maxing out 26mbps now.  BT Engineer will visit in two weeks which isn't great.  They are saying it looks like crossed wires???  Nothing in my house has changed apart from clicking 'change subscription'.
Has anyone else had a similar issue and any advice?  If this doesn't work out I'll just cancel my contract.
Thanks a lot,
Alex.
13 REPLIES 13
Message 2 of 14
Re: Fibre 2 Upgrade - Slower Speed
Message 3 of 14
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
have you tried connecting to test socket with a filter to see if that improves your connection speed
Someone may then be able to offer help/assistance/suggestions to your problem
Message 4 of 14
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ65241335
Firmware version:
SG4B1000E020
Firmware updated:
26-Aug-2019
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 21 Hours 57 Minutes 30 Seconds
Data rate:
7.99 Mbps / 31.70 Mbps
Maximum data rate:
8020 / 32274
Noise margin:
6.5 dB / 6.1 dB
Line attenuation:
29 dB
Signal attenuation:
18.5 dB / 29 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
605 MB Uploaded / 19 GB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C5WP
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-C5WP-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:9A:F5:45
Software variant:
Boot loader:
7.33.1
Message 5 of 14
I have connected to the test socket and the speeds are still 26mbps. So that confirms nothing is wrong with my internal wiring. I suspect it's the hub or an issue at BT's end since making the switch.
Message 6 of 14
Quiet line test?
Message 7 of 14
Quiet line test was silent.
Message 8 of 14
even your attainable is only 32mb and with your attenuation you are a long way from the cabinet - which conflicts with the dslchecker results which shows speed range 80/60mb
can you connect to test socket and post new stats   was it your number repeated on quiet line test
Message 9 of 14
Plugged directly into test socket and quiet line test was good.
Product name:
BT Hub 6A
Serial number:
+084316+NQ65241335
Firmware version:
SG4B1000E020
Firmware updated:
26-Aug-2019
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 0 Hours 1 Minutes 33 Seconds
Data rate:
8.97 Mbps / 30.21 Mbps
Maximum data rate:
8975 / 30329
Noise margin:
6.3 dB / 6.3 dB
Line attenuation:
21 dB
Signal attenuation:
18.3 dB / 21 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
75 kB Uploaded / 105 kB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-C5WP
Smart (Channel 1)
BTHub6-C5WP-5
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:9A:F5:45
Software variant:
Boot loader:
7.33.1
Message 10 of 14
