Message 1 of 4
Fibre installers
Hi for fttp. Cable from pole to house and install is there 2 engineers?
Thank you
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: Fibre installers
Only one usually.
Message 3 of 4
I think there could be 2 engineers involved. Initially an engineer does the step 1 task which is a line of site check and to install the overhead fibre to the house. The internal bit is done by another engineer at a later stage
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
@Devon_Dave  Most installs are now 1 stage, ergo 1 engineer. I'm sure @Starwire will be pleased to confirm.
