Message 1 of 6
New fibre install upload stuck at 50 mbps.
All testing done by cable, cat5e.
Also ran the internal speed test from the BT app that confirmed it won't go above 50 mbps. Download seems about right 800-900.
Any help would be appreciated.
5 REPLIES 5
Message 2 of 6
Re: New fibre install upload stuck at 50 mbps.
if new install you need to wait a few days and up speed your increase
numerous posts on forum if you use search
https://community.bt.com/t5/BT-Fibre-broadband/BT-Fibre-900-Upgrade-Smart-Hub-2-upload-throttling/m-...
Message 3 of 6
Your hub should update within 72hrs and give you full upload speed. Post back then if it has/hasn't happened and the mods will sort it out for you.
Message 4 of 6
Sorry guys, I should have searched first. Knew something wasn't right though so I'm very much relieved.
Message 5 of 6
It's already sorted itself out getting 900/110 now on speedtest.
Message 6 of 6
Good to hear. Thanks for the update.
