Message 1 of 5
Fibre speeds
Tried to get an answer googling this, without success.  Just wondering how fibre speed is limited, e.g.  My speed is 150 but I could move to 300 up to 900.  Are there several cables and some not used?  Or if it's one cable then how is it done?
4 REPLIES 4
Message 2 of 5
Re: Fibre speeds
There's a cap placed on yourline restricting speed to whatever you are contracted at.
Message 3 of 5
Re: Fibre speeds
An optical fibre cable is capable of extremely high speeds, the service it carries is just fixed in software at whatever speed you are paying for.
Message 4 of 5
Re: Fibre speeds
Thanks, that's what I wanted to know. Just curious!
Message 5 of 5
Re: Fibre speeds
I believe the current highest speed carried by a single fibre is 1Pbps! Not in a domestic environment though 😃
