Message 1 of 4
Firmware update wont work on my Whole Home WiFi
I've been trying to check the status of the firmware on my Whole Home Wifi discs but each time I try it says it cannot connect to the auto update server and I should try later. Is this server down?
Stuart
3 REPLIES 3
Message 2 of 4
Re: Firmware update wont work on my Whole Home WiFi
Hi, @broadstairs have you seen this post about the early adopter firmware release?
Neil
Message 3 of 4
I found yesterday that the server was working again and so updated OK.
I did know about the early adopter you mention, however I am not keen on it as I don't have any issues with the discs right now. Also I only update manually as I have to manage my connections because I have two devices which is on wi-fi which update to the net every few seconds and they need managing when I update the discs.
Stuart
Message 4 of 4
@broadstairs No problem, I'm glad you got sorted.
Neil
