Message 1 of 5
Firmware update
Hello, please could someone tell me how I can check and subsequently update my BT Home Hub 5 router’s firmware? Thanks
4 REPLIES 4
Message 2 of 5
Re: Firmware update
@JRD
You cannot update the firmware manually, on any of the BT Home Hubs.
Message 3 of 5
Re: Firmware update
Thanks for the fast response. So does it update automatically or is it just factory set?
Message 4 of 5
Re: Firmware update
automatically and often over night hence why should be left on 24/7
Message 5 of 5
Re: Firmware update
Thank you much appreciated.
