Message 1 of 4
Firmware upgrade on SmartHub 2 lowered speed
Only just upgraded to Halo.
Firmware upgrade on Friday 19th June.
Not happy with speed drop, even on last router was getting 49Mbps
Product code:Smart Hub 2
Firmware version:v0.17.01.12312-BT
Firmware updated:Fri Jun 19 01:25:56 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,17 Hours17 Mins55 Secs
Data rate:7.445 Mbps / 32.399 Mbps
Maximum data rate:7.441 Mbps / 45.645 Mbps
Noise margin:5.8 / 11.2
Line attenuation:11.0 / 22.3
Signal attenuation:11.0 / 23.0
VLAN id:101
Upstream error control:Off
Downstream error control:O
Any advice please appreciated?
3 REPLIES 3
Message 2 of 4
Re: Firmware upgrade on SmartHub 2 lowered speed
Check for noise on your line. 17070 option 2, best with corded phone.
Message 3 of 4
Mine is also slightly lower after you fw release.
Message 4 of 4
Interesting, I’m on FTTP and noticed a slight drop in speed from 75Mbps to 70 Mbps after this recent firmware update. So it can’t be noise on the line....not in my case.
