Message 1 of 1
For Info: BT Virus Protect: Blank McAfee Notification Popup Window...
If anyone is getting this blank popup, don't worry about it and for the record, it IS NOT a BT fault.
I contacted mcAfee tech support and they said that they are working on it and crucially, it DOES NOT lessen security provided by their product.
That's it really, this was for info only, although I have added a few more notes below.
This started a week or so ago on my both my iMac's and my Macbook Air, it is a very regular occurrence (many times a day) and there is no way to close or dismiss the window other that Force Quit via MacOs Activity Monitor.
Important to note: When this pops, if I review McAfee Reports and Security Reports from the Protect Console, there is nothing to show and everything reports a ok - which backs up advice from McAfee.
My Protect version is upto date at v4.11.1.0(751)
I am running on MacOS BigSur 11.5.1
Mark
